Problem
Your Wyze Palm Lock’s main battery will not charge.
Troubleshooting
- Ensure the main battery is being charged correctly.
- The main battery cannot be charged while inserted into Wyze Palm Lock.
- If charging using a power cable and adapter (both sold separately).
- Verify that the power cable being used is a USB-C cable.
- Ensure that the power adapter being used is a 5V2A power adapter.
- Make sure both the cable and adapter are securely connected.
- If charging using Wyze Battery Charging Dock (sold separately):
- Verify that the power cable being used is the USB-C cable that was included with the charging dock and that it is inserted securely.
- Ensure that the power adapter being used is the 5V2A power adapter that was included with the charging dock.
- Make sure that the battery pack is inserted correctly and securely into the charging dock.
- If possible, try charging using an alternate power cable and/or power adapter.
- If the power cable or adapter is determined to be defective, ensure it is recycled or discarded appropriately.
- Ensure the main battery’s status light indicates that it is charging.
- If the battery pack is charging, there should be one green status light.
- If the battery pack is fully charged, both status lights should be solid green.
- If possible, try using an alternate main battery.
- If possible, try installing the main battery in another compatible Wyze device to check if the issue is with the battery or with the lock.
- The main battery is Wyze Removable Battery Pack.
Note: It usually takes about 9 hours to fully charge the main battery from 0-100%. The backup battery can only be charged by the main battery, and only when both are installed in Wyze Palm Lock.
