Wondering what that error on your Wyze Scale Ultra BodyScan is all about? Here's a quick guide to each error message.
| Failed | Update Failed | ||
| Wi-Fi connection failed. Please move the scale closer to your router and try again. | Scale update failed. Please try to update the scale again. | ||
| Offline | Low Battery | ||
| The server connection failed. Please check your network and try again. | The batteries are low. Please replace the batteries. | ||
| Updating | Error | ||
| Updating, please do not turn off the scale. | The weight exceeds the upper limit on the device and cannot be displayed. | ||
| Calibrated | Factory Reset | ||
| The device was not zeroed when measuring. Please wait until the device is zeroed and then measure again. | The device data has been cleared and reset. | ||
