Problem
The battery life on my Wyze Scale Ultra BodyScan seems lower or higher than it should be.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
- If possible, check that your Wyze Scale Ultra BodyScan’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Force close the Wyze app, then reopen it.
- Make sure the batteries being used are four 1.5V AAA batteries.
- Power cycle Wyze Scale Ultra BodyScan.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale Ultra BodyScan.
- On the back of the scale in the battery compartment, find the UNIT button.
- Press and hold it for 3 seconds until the scale’s display shows "Clear".
- Set up the scale as new.
