My Wyze Scale Ultra BodyScan’s firmware fails to update.
Problem
When you try to update your Wyze Scale Ultra BodyScan, it fails.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Verify that the scale is connected to Wi-Fi.
    1. In the Wyze app, go to Wyze Scale Ultra BodyScan’s settings.
    2. If Wi-Fi is not enabled for the scale, tap Connect Wi-Fi.
    3. If Wi-Fi is already enabled for the scale, tap Reset Wi-Fi.
    4. Follow the in-app steps to connect the scale to Wi-Fi
  3. Ensure Wyze Scale Ultra BodyScan has good signal strength.
    1. You can check this in the Wyze app by going to the scale’s settings > Device Info > Signal Strength.
    2. If it has 2 bars or less, try moving the scale closer to the router.
  4. Force-close the app and wait 30 minutes before checking whether the update was successful.
  5. Move the scale and device with the Wyze app closer to the router during the update.
  6. Reboot the Wi-Fi router and then attempt the update again.
  7. Power cycle Wyze Scale Ultra BodyScan.
    1. Remove the batteries for 10 seconds, then reinstall them.
  8. Factory reset Wyze Scale Ultra BodyScan.
    1. On the back of the scale in the battery compartment, find the UNIT button.
    2. Press and hold it for 3 seconds until the scale’s display shows "Clear".
    3. Set up the scale as new.
