My Wyze Scale Ultra BodyScan’s screen isn’t showing the correct info.
Problem
You are not seeing the information you wish to see on your scale’s built-in screen.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan’s firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Adjust the Screen Settings.
    1. In the Wyze app, go to Wyze Scale Ultra BodyScan’s settings.
    2. Tap Screen Settings.
    3. Make sure the desired metrics are selected, then tap OK.
  4. Power cycle Wyze Scale Ultra BodyScan.
    1. Remove the batteries for 10 seconds, then reinstall them.
  5. If still not showing the desired metrics, factory reset Wyze Scale Ultra BodyScan.
    1. On the back of the scale in the battery compartment, find the UNIT button.
    2. Press and hold it for 3 seconds until the scale’s display shows "Clear".
    3. Set up the scale as new and readjust the screen settings.
