Problem
The detailed report will not populate, even though it populated in the past, or the report disappears.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that your Wyze Scale Ultra BodyScan’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Ensure the correct user profile is selected in the Wyze app while measuring.
- Make sure Body Segments are enabled.
- In the Wyze app, go to Wyze Scale Ultra BodyScan’s settings.
- Ensure Body Segments is enabled.
- Attempt to measure again, ensuring that measuring is done correctly.
- The scale should be placed on a hard, flat surface.
- Feet must be barefoot.
- Excessively dry or damp feet may result in incorrect or no measurements.
- Knees should not be touching.
- Grip the handle with all fingers, with thumbs placed on the sensor area.
- Keep arms at a 45° angle while holding the handle.
- Remain on the scale until measuring is complete.
- Power cycle Wyze Scale Ultra BodyScan.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale Ultra BodyScan.
- On the back of the scale in the battery compartment, find the UNIT button.
- Press and hold it for 3 seconds until the scale’s display shows "Clear".
- Set up the scale as new.
Note: We do not recommend having multiple versions of Wyze Scales on a single Wyze account, as measuring with different scales may disrupt the report.
