I’m unable to purchase the Wyze service.
Problem
You’re unable to purchase a Wyze Service on the web or via in-app purchase.
Impacted Services:
  • All Wyze Services
Note: Wyze Services are not compatible with Wyze Cam v1.
Troubleshooting
  1. Verify where the purchase of the subscription is being attempted.
    • We recommend purchasing through wyze.com for the best experience.
  2. If purchasing through the Wyze app, confirm that the app is up to date.
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  3. Ensure that the correct email is being used.
    1. The email being used to purchase the subscription should be the same email address used to sign into the Wyze account.
  4. Check that the payment method being used is entered correctly, completely, and is not expired.
  5. Try using a different browser or incognito browser for the purchase.
  6. If possible, try using a different payment method.
