My Wyze Scale Ultra BodyScan Plus will not power on.
Problem
The screen on your Wyze Scale Ultra BodyScan Plus handle will not turn on when you step on the scale.
Troubleshooting
  1. Ensure that the batteries are installed correctly in the handle compartment, with the positive sides aligned with positive and the negative sides aligned with negative.
  2. Make sure the batteries being used are four 1.5V AAA batteries.
  3. If already set up, ensure Power Saver Mode is disabled.
    1. In the Wyze app, go to Wyze Scale Ultra BodyScan Plus’ settings.
    2. Toggle off Power Saver Mode.
  4. Try alternate batteries, if possible.
