My Wyze Scale Ultra BodyScan Plus is not showing the correct weight.
Problem
The scale isn’t showing the correct weight.
Note: There is a range of acceptable measurement differences. The scale tolerance of Wyze Scale Ultra BodyScan Plus is:
  • 11-132lb: ± 0.66lb
  • 132-265lb: ±0.88lb
  • 265-400lb: ±1.1lb
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Ensure that measuring is done correctly.
    • The scale should be placed on a hard, flat surface.
    • Feet must be barefoot.
      • Excessively dry or damp feet may result in incorrect or no measurements.
    • Knees should not be touching.
    • Grip the handle with all fingers, with thumbs placed on the sensor area.
    • Keep arms at a 45° angle while holding the handle.
    • Remain on the scale until measuring is complete.
  4. Calibrate the scale.
    1. Step on Wyze Scale Ultra BodyScan Plus to activate it.
    2. Step off the scale, and let it return to 0.0 lb.
  5. Verify that the scale is syncing with the Wyze app.
    1. In the Wyze app, select Wyze Scale Ultra BodyScan Plus, then step on the scale to activate it.
    2. Ensure that “Connected” displays in the app and the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
  6. Clean the scale’s surface.
    1. Wipe off the scale’s surface with a damp cloth.
  7. Power cycle Wyze Scale Ultra BodyScan Plus.
    1. Remove the batteries for 10 seconds, then reinstall them.
  8. Factory reset Wyze Scale Ultra BodyScan Plus.
    1. Below the handle display, find the touch-sensitive UNIT button.
    2. Press and hold it until the handle display shows "Clear".
    3. Set up the scale as new.
