Wyze Scale Ultra BodyScan Plus Integrations Troubleshooting
Problem
Your Wyze Scale Ultra BodyScan Plus is not syncing with third-party integrations.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Verify that the third-party app is compatible with Wyze Scale Ultra BodyScan Plus.
    • Android - Wyze Scale Ultra BodyScan Plus is compatible with Health Connect.
    • iOS - Wyze Scale Ultra BodyScan Plus is compatible with Health.
  4. Ensure the desired third-party app is functioning normally.
  5. Delete any integrations and set them up again.
    1. In the Wyze app, go to Wyze Scale Ultra BodyScan Plus’ settings.
    2. Tap Third Party Integration.
    3. Select the integration, then tap Unauthorize.
    4. Re-enable the integration.
  6. Take another measurement and check if the data was added to the integration.
