My Wyze Scale Ultra BodyScan Plus’ battery level is incorrect.
Problem
The battery life on your Wyze Scale Ultra BodyScan Plus seems lower or higher than it should be.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app, then re-open it.
  4. Make sure the batteries being used are four 1.5V AAA batteries.
  5. Power cycle Wyze Scale Ultra BodyScan Plus.
    1. Remove the batteries for 10 seconds, then reinstall them.
  6. Factory reset Wyze Scale Ultra BodyScan Plus.
    1. Below the handle display, find the touch-sensitive UNIT button.
    2. Press and hold it until the handle display shows "Clear".
    3. Set up the scale as new.
