My Wyze Scale Ultra BodyScan Plus is not recording my heart rate.
Problem
You are having trouble measuring your heart rate, or the heart rate is not showing in the app.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app, then re-open it.
  4. Verify that the Wyze app has permission to access the mobile device’s camera.
    • This can be checked in the phone’s settings.
  5. Ensure that measuring is done correctly.
    • The finger must be placed on the mobile device’s main camera lens (not the flash).
    • There should not be anything obstructing the finger.
      • Excessively dry or damp fingers may result in incorrect or no measurements.
      • Remove any case covering the camera, if needed.
    • Remain still and breathe normally.
    • The finger must remain on the camera until the measurement is complete.
