My Wyze Scale Ultra BodyScan Plus is showing incorrect body measurements.
Problem
Your Wyze Scale Ultra BodyScan Plus is showing unexpected or inconsistent body measurements, or data fluctuates significantly between measurements.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
    1. Unpair any unused Bluetooth® devices from the phone/tablet.
    2. Toggle Bluetooth® off/on.
  4. Ensure that measuring is done correctly.
    • The scale should be placed on a hard, flat surface.
    • Feet must be barefoot.
      • Excessively dry or damp feet may result in incorrect or no measurements.
    • Knees should not be touching.
    • Grip the handle with all fingers, with thumbs placed on the sensor area.
    • Keep arms at a 45° angle while holding the handle.
    • Remain on the scale until measuring is complete.
  5. Clean the scale’s surface.
    1. Wipe off the scale’s surface with a damp cloth, then try again.
  6. Verify that the scale is syncing with the Wyze app.
    1. In the Wyze app, select Wyze Scale Ultra BodyScan Plus, then step on the scale to activate it.
    2. Ensure that “Connected” displays in the app and that the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
  7. Ensure the correct user profile is selected in the Wyze app while measuring.
  8. Verify that the profile’s personal information (i.e., body type, year of birth, etc.) is correct in the Wyze app.
    1. In the Wyze app, go to Wyze Scale Ultra BodyScan Plus’ settings > Users.
    2. Ensure that Pregnancy/Weight-Only Mode is disabled.
  9. Power cycle Wyze Scale Ultra BodyScan Plus.
    1. Remove the batteries for 10 seconds, then reinstall them.
  10. Factory reset Wyze Scale Ultra BodyScan Plus.
    1. Below the handle display, find the touch-sensitive UNIT button.
    2. Press and hold it until the handle display shows "Clear".
    3. Set up the scale as new.
Note: Body composition metrics (body fat %, water %, etc.) are only available for people between the ages of 10-100 years old. Children under 10 and seniors over 100 will not be able to access the body composition features. For users between the ages of 10-17, the body composition metrics are only for reference.
