Problem
You are not seeing the information you wish to see on your scale handle’s screen.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Adjust the screen settings.
- In the Wyze app, go to Wyze Scale Ultra BodyScan Plus’ settings.
- Tap Customize Scale.
- Make sure the desired metrics are selected, then tap OK.
- Power cycle Wyze Scale Ultra BodyScan Plus.
- Remove the batteries for 10 seconds, then reinstall them.
- If still not showing the desired metrics, factory reset Wyze Scale Ultra BodyScan Plus.
- Below the handle display, find the touch-sensitive UNIT button.
- Press and hold it until the handle display shows "Clear".
- Set up the scale as new and readjust the screen settings.
