My Wyze Scale Ultra BodyScan Plus’ handle is not recording my body metrics.
Problem
You are unable to get your body composition metrics recorded when measuring using the handle.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Ensure the correct user profile is selected in the Wyze app while measuring.
  4. Calibrate the scale.
    1. Step on Wyze Scale Ultra BodyScan Plus to activate it.
    2. Step off the scale, and let it return to 0.0 lb.
  5. Attempt to measure again, ensuring that measuring is done correctly.
    • The scale should be placed on a hard, flat surface.
    • Feet must be barefoot.
      • Excessively dry or damp feet may result in incorrect or no measurements.
    • Knees should not be touching.
    • Grip the handle with all fingers, with thumbs placed on the sensor area.
    • Keep arms at a 45° angle while holding the handle.
    • Remain on the scale until measuring is complete.
  6. Power cycle Wyze Scale Ultra BodyScan Plus.
    1. Remove the batteries for 10 seconds, then reinstall them.
  7. Factory reset Wyze Scale Ultra BodyScan Plus.
    1. Below the handle display, find the touch-sensitive UNIT button.
    2. Press and hold it until the handle display shows "Clear".
    3. Set up the scale as new.
