Problem
Wyze Scale Ultra BodyScan Plus shows your weight on the screen, but the Bluetooth® symbol and other measurements are not displayed in the Wyze app.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that your Wyze Scale Ultra BodyScan Plus’ firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Ensure the scale is not currently connected to another device.
- Wyze Scale Ultra BodyScan Plus can only be paired with one device at a time.
- Force close the Wyze app, then re-open it.
- Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
- Unpair any unused Bluetooth® devices from the phone/tablet.
- Toggle Bluetooth® off/on.
- Turn off the mobile device, then turn it back on.
- Verify that the scale is syncing with the Wyze app.
- In the Wyze app, select Wyze Scale Ultra BodyScan Plus, then step on the scale to activate it.
- Ensure that “Connected” displays in the app and the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
- Check that there is no unclaimed data in the app.
- In the Wyze app, select Wyze Scale Ultra BodyScan Plus.
- If there is unclaimed data, there will be a “You have unclaimed data.” message at the top of the screen.
- If so, tap the message to assign the unclaimed data to the correct user, and tap Claim once done.
- Power cycle Wyze Scale Ultra BodyScan Plus.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale Ultra BodyScan Plus.
- Below the handle display, find the touch-sensitive UNIT button.
- Press and hold it until the handle display shows "Clear".
- Set up the scale as new.
