Using Essential Automations in the Wyze app
Topics covered in this article:
👋 New to Wyze and Automations? Start here:Using Automations in the Wyze app
What are Essential Automations?
Essential Automations are some of our most-popular Automations, already set up in the Wyze app for you to use with just a few taps. Instead of manually creating an automation, select an Essential Automation and customize it before tapping Save.
Some Essential Automations are:
  Type of Automation How it works Requires
Turn on lights when a person is detected Device trigger If a camera detects a person, the lights turn on. Wyze camera, lighting and a plug, and Cam Plus / Protect subscription
I'm home Shortcut Tap this shortcut to turn off your cameras when home. Any Wyze camera
Turn lights off when I'm away Location trigger When you leave an area, the lights turn off. Wyze lighting or plugs, location enabled
Turn alerts off at night Schedule App notifications turn off from sunset to sunrise. Any Wyze device
🤫 There are hidden Essential Automations that display based on the Wyze devices you have. Get a new Wyze device? Keep an eye 👀 out for new Essential Automations to try out!
Where do I find Essential Automations?
Find Essential Automations on the Automations tab in the Wyze app.
How do I use Essential Automations?
  1. On the Home screen of the Wyze app, tap Automations.
  2. Scroll down, and tap an Essential Automations from the list.
    • Or, tap See All for a full list of automations to choose from.
  3. Update the automation if needed, then tap Save.
How do I edit or delete an Essential Automation?
  2. Tap on the automation you want to edit or delete.
    • To edit, make your changes and tap Save.
    • To delete, tap Delete Automation, and confirm.
