Using Wyze App Widgets on iOS
What are Wyze app widgets?
Wyze app widgets are a way to manage your Wyze devices from your iOS or Android home screen.
Types of Wyze widgets
  • Device: Check the status of your selected device.
  • Events: View what Events are available in the Wyze app.
  • Shortcuts: Quickly control your Wyze Shortcuts.
  • Wyze Home Monitoring: Your home's monitoring status at a glance.
How do I add a Wyze widget on iOS?
1. Tap and hold on the home screen.
2. Tap Edit.
3. Tap Add Widget.
4. Search or scroll to tap Wyze.
5. Swipe to select the type of widget you want to add.
6. Tap Add Widget.
7. Tap Done.
How do I add a widget to the lock screen on iOS?
1. Tap and hold on the home screen to display Customize.
2. Tap Customize.
3. Tap Add Widgets.
6. Tap or drag the widgets that you want to add to the Lock Screen.
7. If you add a Device widget, click it to select the device to access.
8. When finished, tap any empty area, then tap Done.
To remove a Wyze app widget on iOS:
Tap and hold on the widget, then tap Remove Widget.
