My Wyze Scale's battery level is incorrect.
Problem
The battery life on your Wyze Scale is presented as lower or higher than it should be.
Troubleshooting
  1. Check that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, confirm that Wyze Scale’s firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app.
  4. Power cycle Wyze Scale.
    1. Remove the batteries for 10 seconds, then reinstall them.
  5. Replace the batteries, if needed.
  6. Delete Wyze Scale from the app.
    1. In the Wyze app, navigate to Wyze Scale's settings > Delete Device.
    2. Set up the scale as new.
