Wyze Scale Connectivity Troubleshooting
Problem
Wyze Scale is showing your weight on the screen, but does not display the BluetoothⓇ symbol or other measurements in the Wyze app. Wyze Scale does not connect to the Wyze app.
Troubleshooting
  1. Check that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, confirm that Wyze Scale’s firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Check if the scale was previously connected to or is currently connected to another device.
    • Wyze Scale can only be paired with one mobile device at a time.
  4. Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
    1. Toggle Bluetooth® off/on.
  5. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  6. Log out of the Wyze app.
  7. Force close the Wyze app, then log back in.
  8. Reboot the mobile device.
  9. Power cycle Wyze Scale.
    1. Remove the batteries for 10 seconds, then reinstall them.
  10. Delete Wyze Scale from the app.
    1. In the Wyze app, navigate to Wyze Scale's settings > Delete Device.
    2. Set up the scale as new.
