I didn’t receive a call or text from Noonlight.
Problem
Your system was triggered, but you never received a call or text from Noonlight.
Troubleshooting
  1. Confirm your phone number is up to date.
    1. You can check this in the Wyze app by going to the Monitoring tab > navigating to the Cam Protect/Wyze Home Monitoring settings > My information > Phone Number.
    2. If you've recently updated your phone number in the Wyze app, check that you've received a verification code from Wyze.
  2. Ensure that your phone is not in Do Not Disturb mode.
  3. Verify that you are receiving calls and texts from other people.
  4. Check that the system was armed at the time and that an alarm was triggered.
  5. Confirm that the sensor that triggered the alarm was assigned to the mode your system was armed in.
    1. Navigate to the Monitoring tab then tap on the home monitoring settings.
    2. Tap Home & Away.
  6. Ensure your Wyze Home Monitoring Subscription is still active.
    2. Tap Subscriptions.
