Wyze Headphones Connectivity Troubleshooting
Problem
Your Wyze Headphones show offline in the Wyze app, load slowly, or disconnect frequently.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Make sure the headphones are fully charged and turned on.
    1. If your Wyze Headphones aren’t charged, fully charge them, then make sure they are on and the status light is on.
    2. Short on time? You can do a Quick Charge by charging your headphones for 10 minutes.
  3. Check the Bluetooth® connection.
    1. In your phone’s settings, toggle Bluetooth® off and then back on.
    2. Ensure your headphones are within Bluetooth® range of your phone.
      • This distance varies by device but is generally about 30 feet.
    3. If the headphones were previously connected, forget them in the Bluetooth® settings and then pair them again.
      • Note: If your headphones were previously connected to other phones/tablets, you’ll need to unpair them from those devices as well.
    4. If there are other devices connected to your phone via Bluetooth® or other apps currently using Bluetooth® that may be causing interference, unpair the devices or close the apps.
  4. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. If possible, check that your Wyze Headphones firmware is up to date.
    2. If there is an update available for the headphones, please move forward with updating them.
  6. Force close the Wyze app.
  7. Restart your phone.
  8. Power cycle the headphones.
    1. Single-press the power button on the right ear cup. You should hear a “power off” voice prompt.
    2. Wait 10 seconds, then single-press the power button again. You should hear a “power on” voice prompt.
  9. Delete the headphones from the Wyze app and set them up like new.
  10. Try a different phone if possible.
