Problem
The headphones do not charge when plugged into power with the included charging cable.
Troubleshooting
- Check that your Wyze app is up to date.
- In the app, tap Accounts > About.
- The app version will be listed beneath the Wyze logo.
- You can compare your app version to the most up-to-date version listed on our Release Notes and Firmware Page.
- Check that your Wyze Headphone’s firmware is up to date.
- You can check this by going to Accounts > About..
- If there is an update available for the headphones, please move forward with updating them.
- Make sure there is nothing blocking the charging port such as dirt or dust.
- Make sure you are using the USB-C cable that was included with the headphones and that it is securely connected.
- Try charging Wyze Headphones with an alternate power source or power cable.
