Grouping Multiple Devices
Use the Wyze app to collect your Wyze devices into groups to view and manage them easily.
This article covers the following topics about managing Wyze device groups:
To create a group of Wyze devices:
  2. On the Add menu, tap Device Group.
  3. Select the product type you would like to group.
    • Choose Camera Group for cameras, Plug Group for smart plugs, etc.
    • Only one device type per group - cameras and plugs can't be grouped together.
  4. Enter a name for the group at the top of the screen.
  5. Add a checkmark next to every device you want in the group.
  6. Tap Done on the top right.
To add a group to the Favorites tab:
  1. On the Home tab of the Wyze app, tap Devices.
  2. Scroll or collapse the list to reach Device Groups.
  3. Tap the star icon next to the group you want added to Favorites.
To view multiple devices in a group:
  • On the Home tab, tap on the group on your Favorites or Devices list.
This will display all of the devices in that group. If you tap on a camera group, you will be able to view all of the Live streams on the same screen.
To manage an individual device in a group:
  • Tap on the group name, then the device you want to manage.
👉  Managing a camera group? Only one camera's audio in a group can play at any given time.
To edit a group of devices:
  1. On the Home tab, tap on the group on your Favorites or Devices list.
  2. Tap the Settings gear on the top right.
    • To rename a group:
      1. Tap Name at the top of the screen.
      2. Enter the name in the window, then tap Done.
    • To reorder devices in a group*:
      1. Tap [Devices] in Group (ex. Cameras in Group).
      2. Press and drag the three horizontal lines icon next each device you want to rearrange.
      3. Tap Save.
    • To remove devices in a group:
      2. Tap the red icon next to the device you want to remove.
      3. Tap Save.
To delete a group:
  1. On the Home tab, tap on the group on your Favorites or Devices tab.
  2. Tap the Settings gear to open the Group Settings.
  3. Tap Delete [Device] Group (ex. Delete Bulb Group).
  4. Tap Delete to confirm.
Additional Notes:
  • There is no limit to the number of devices that can be added to a group.
  • You can only group similar devices together.
    • For example, Wyze Cam v3 and Wyze Video Doorbell Pro can be grouped together, but a Wyze Cam v3 and a Wyze Bulb Color cannot be grouped together.
  • Removing devices from a group will not delete the device from your account. Only the group will be affected.
  • When you create a group, the individual devices will not display on the Home tab. You can view them in the group itself by tapping on the group.
