Wyze App Notifications
Notifications from the Wyze app let you know what's going on with your Wyze devices at a glance. Customize your Notifications on the Account tab of the Wyze app.
⚡️  Heads up! The Wyze app got a major update on 7/24/2024 with Wyze App 3.0. The home tab looks and functions differently, so check out the new features here and find the FAQ on wyze.com.
📌 Tip: To change your Wyze app Notifications settings, open the Wyze app and tap on Account > Notifications
Types of Wyze Notifications:
To turn on and off your Wyze app Notifications
In-App Notifications
While in the Wyze app, get notified about Wyze news and general updates.
  1. To turn on in-app notifications:  In the Wyze app, tap Account > Notifications > In-app Notifications. Tap the toggle to on.
    1. Tap the toggle next to News & Updates to receive those promotional notifications.
    2. To turn off in-app notifications, Account > Notifications > In-app Notifications. Tap the toggle to off.
Push Notifications
Get device notifications and/or promotional notifications pushed directly to your phone.
  1. To turn on push notifications: In the Wyze app, tap Account > Notifications > Push Notifications. Tap the toggle next to Enable to on.
    • To turn off push notifications, tap the toggle off.
  2. Tap the Notification Sound to select the sound that plays.
  3. Tap Voice Over IP for Wyze Video Doorbell to receive an internet phone call instead of a push notification when your doorbell is pressed.
Note: Beginning in Wyze app 3.9+, Event video notifications will play a short GIF-like preview. This feature will be available for Cam Plus, Cam Unlimited, and Cam Unlimited Pro users and cannot be disabled.
Text Notifications
Get text messages with Wyze news and promotions about 2-4 times per month.
  1. In the Wyze app, tap Account > Notifications > Text Notifications. Tap the toggle on.
  2. Enter your phone number. Tap Submit.
    • To turn off text notifications, Account > Notifications > Text Notifications. Tap the toggle to off.
App Discovery
Get Wyze app tips and tricks on Discover Cards on the Home tab of the app, customized to your Wyze Devices and Services.
⚡️ As of 7/24/2024, App Discovery has been removed in Wyze app versions 3.0 and above.
  1. To turn on App Discovery notifications, tap Account > Notifications > App Discovery
  2. Tap Frequency to select how often you'd like to receive new Discover tips.
  3. Tap the Event Reports toggle to receive a Discover card (based on the frequency set) with a summary of your events per device.
Snooze (Global) Notifications
Control notifications for all devices associated on your Wyze account with the tap of a bell.
To turn off or "Snooze" Global Notifications:
  1. In the Wyze app, tap the bell icon.
  2. Choose the duration: 30 min, 1 hour, until 8 AM tomorrow, until I turn it back on, and Custom.
    1. Until I turn it back on: You will not receive any notifications until you tap the bell again.
    2. Custom: Notifications will turn off until a specific time today or tomorrow.
Notifications ON Notifications Off
Note: Turning off notifications doesn’t impact Event Recording. Any Events you've chosen to be recorded will still be recorded, but you won't receive a notification if you've turned them off.
Device Notifications
For Wyze Cam and Wyze Sense devices, you can select specific Events to receive notifications for, like when your Wyze Cam Floodlight v2 detects a moving vehicle.
To change your Device Notifications:
  • In the Wyze app, tap on your Wyze device.
  • Tap on the Settings gear, then Notifications.
  • Tap the toggle to enable Notifications, then tap the boxes next to which Events you'd like to be notified about.
⚡️ Snooze Notifications override all Device Notifications settings. If you have leak notifications enabled for Wyze Leak Sensor, but global notifications are disabled, you will not receive a notification from the leak sensor.
Not every Wyze Device has the same Notifications options. Wyze Cams notify you about Events like motion and sound detection, and a lot more with a subscription Cam Plus. Wyze sensors, like Wyze Climate Sensor, will notify you about temperature and humidity changes. See below:
Wyze Cam with Cam Plus Wyze Climate Sensor
Additional Notes
  • Not receiving notifications?
    • On your mobile device, make sure Wyze is on your Allow list for Notifications.
    • In the Wyze app, make sure Global Notifications are turned on.
    • On your Wyze device, go to Settings > Notifications and make sure it's toggled on.
  • Shared users:
    • Detection & Alarm Settings: Shared users cannot modify these settings; only the primary user can.
    • Notification Settings: Shared users can independently manage their notification settings and use the Snooze button. This is available on Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Battery Video Doorbell, Wyze Solar Cam Pan, Wyze Bulb Cam, and Wyze Cam Floodlight v2.
  • The Snooze Notifications bell controls all device notifications. If it's toggled off, you will not receive any device notifications from the Wyze app until the duration you've set has passed. Events will still be recorded and saved.
