Problem
Your Wyze Bulb doesn't light up in a light socket and doesn't appear to be powered.
Troubleshooting Steps:
If you’re using the Wyze app:
- Confirm your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
- Check that your Wyze Bulb’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the bulb, please move forward with updating it.
- Ensure the bulb is securely inserted into the socket.
- Confirm that the light fixture the bulb is installed in is physically turned on.
- Check if the bulb is in a light socket with a dimmer switch. It might be on the wall, or on the power cord that runs to the light.
- If it is on a dimmer switch and you cannot move it to a different socket, try these steps:
- Set the dimmer switch to its highest setting and see if the bulb turns on.
- If it turns on, use the Wyze app to adjust the bulb brightness.
- Note: Wyze Bulb should only be dimmed using the Wyze app (or voice commands).
- Check to ensure the Power Loss Recovery setting is set to Turn the lights on.
- Factory reset Wyze Bulb.
- Turn on/off the light switch associated with the bulb 3 times.
- Wait for the bulb to start pulsing slowly.
- Once the bulb starts pulsing, you can either set it up again or turn the light off to preserve the factory state.
- If the issue persists, try moving the bulb to a different light fixture.
- If you’re unable to move it to a different fixture, try a different bulb in the same light fixture.
If you’re not using the Wyze app:
- Ensure that the fixture the bulb is installed in is physically powered on.
- If it is in a socket with a dimmer switch, move the bulb to a different socket, as dimmer switches are not recommended.
- Note: Bulbs using dimmer switches need to have the brightness adjusted from within the app only. Using the physical dimmer switch will cause functionality problems.
- If it is in a dimmer switch and cannot be moved to a different socket, ensure that the dimmer switch is turned up to its highest setting.
- Try moving the bulb to a different light fixture.
Example of a dimmer switch:
