My Wyze Bulb is flickering.
Problem
Your Wyze Bulb flickers or blinks randomly.
Troubleshooting
  1. Confirm your Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Check that your Wyze Bulb’s firmware is up to date.
    2. If there is an update available for the bulb, please move forward with updating it.
  3. Ensure the bulb is securely inserted into the socket and that the light switch is turned on.
  4. Power cycle Wyze Bulb.
    • Turn off the bulb manually with the light switch for 5 seconds, then turn it back on.
  5. Confirm if the bulb is in a socket with a dimmer switch.
    • If it is in a socket with a dimmer switch, move the bulb to a different socket, as dimmer switches are not recommended.
    • If it is in a dimmer switch and cannot be moved to a different socket, ensure that the dimmer switch is turned up to its highest setting.
  6. Try moving the bulb to a different socket, closer to the router.
  7. Reboot the router.
  8. Factory reset Wyze Bulb.
    1. Turn the light switch associated with the bulb off/on 3 times.
    2. Wait for the bulb to start pulsing slowly.
    3. Once the bulb starts pulsing, set it up like new.
Example of dimmer switches:
