Wyze Bulb Connectivity Troubleshooting
Problem
Your Wyze Bulb shows offline in the Wyze app, has trouble connecting, or disconnects frequently.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Bulb's firmware is up to date.
    2. If there is an update available for the bulb, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. Confirm that your bulb is connected to a 2.4 GHz Wi-Fi network and that the network is functioning normally.
  5. Ensure the bulb is securely inserted into the socket.
  6. Verify that the fixture the bulb is installed in is physically powered on.
  7. Check if the bulb is in a socket with a dimmer switch.
    • If it is in a socket with a dimmer switch, move the bulb to a different socket, as dimmer switches are not recommended.
    • If it is in a dimmer switch and cannot be moved to a different socket, ensure that the dimmer switch is turned up to its highest setting.
  8. Try moving the bulb to a different socket, closer to the router.
  9. Reboot your Wi-Fi router.
  10. Power cycle your Wyze Bulb.
    1. Manually turn off the bulb via the light switch for 5 seconds, then turn it back on.
  11. Factory reset Wyze Bulb.
    1. Turn the light switch associated with the bulb off/on 3 times.
    2. Wait for the bulb to start pulsing slowly.
    3. Once the bulb starts pulsing, set it up like new.
