How to upgrade your Wyze Cam Outdoor firmware
Whenever there is a firmware update, you'll receive a prompt to update. If you dismiss the prompt without updating, you can still do so later.
To update your Wyze Cam Outdoor firmware:
  1. In the Wyze app, tap Home, then your Wyze Cam Outdoor.
  2. Tap on the Settings icon SettingsGear.png on the top right, then Device Info.
  3. Tap Firmware Upgrade to upgrade if a new version is available.
