My camera lens is blurry from condensation. What do I do?
It should clear up on its own.
As with any lens, condensation can build up on your Wyze Cam Outdoor from rapid temperature and humidity changes. This can cause the live stream image to become blurry or foggy.
We recommend you let the condensation to clear up on its own, which should happen when the temperature stabilizes. If you're noticing a lot of morning dew, for instance, waiting until later in the morning when the weather warms up should do the trick.
