My Wyze Bulb Cam won't turn on.
Problem
Your Wyze Bulb Cam won’t power on or doesn’t have a status light.
Troubleshooting
  1. Check if the camera is in a socket with a dimmer switch.
    • If it is in a socket with a dimmer switch, we recommend moving the camera to a different socket, as dimmer switches are not recommended.
      • Note: If using dimmer switches, the brightness will need to be adjusted from within the Wyze app only. Using the physical dimmer switch may cause functionality problems.
    • If it is in a dimmer switch and it cannot move it to a different socket, ensure that the dimmer switch is turned to its highest setting.
  2. Verify that the camera is installed securely in the socket.
    • Note: It should not be too tight or too loose.
  3. Ensure that the fixture where Wyze Bulb Cam is installed is physically powered on.
    1. Turn it off, then back on.
  4. If Wyze Bulb Cam was already set up in the Wyze app, ensure the status light is enabled.
    1. In the Wyze app, go to the camera’s settings > Advanced Settings > Camera Status Lights > then toggle the lights off and on.
  5. Check the socket type. Make sure it’s a standard E26 socket that is compatible with A19 shape bulbs, with a power output bigger than 15W.
  6. Move the camera to a different socket to determine if there is an issue with the original socket.
    1. If unable to move to a different location, try installing a regular light bulb in the socket to see if it powers on.
