My Wyze Bulb Cam’s light is not turning off.
Problem
Wyze Bulb Cam’s light will not turn off, or it stays on during the night.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
  2. If possible, check that Wyze Bulb Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. From the camera’s live stream, tap the device icon to turn the light off.
    • Note: If the device’s live stream is fully connected, but the light cannot be turned off manually via the live stream, please reach out to our Wizards Support Team.
  5. Verify that the Detection Settings are set correctly.
    1. Navigate to the camera’s settings > Detection Settings.
    2. Change the Motion Detection Sensitivity to Low.
  6. Verify that the Bulb Settings are set correctly.
    1. Navigate to the camera’s settings > Bulb Settings.
    2. Under Activate When, tap Motion.
      1. Tap Lights Off Timer and set it to 15 s while testing, then tap Save.
      2. Tap Schedule and verify it is set to your preferred timeframe.
        1. Set a different schedule to clear any stuck settings, then set it back to your preferred timeframe.
        2. Test the camera during the set timeframe.
    3. Under Ambient Light Settings, tap on Ambient Light.
      1. Toggle it off while testing.
      2. If you want to keep it enabled:
        1. Verify that the Brightness Level is set to Low.
          • Note: This is different from the brightness level when motion is detected.
        2. Check the Ambient Light Schedule.
          3. Note: Having Ambient Light enabled will keep the camera’s light turned on during the scheduled time.
  7. Ensure that Wyze Bulb Cam has a good signal strength.
    1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
    2. If it has less than 2 bars, try moving the router and camera closer together.
    3. If possible, adjust the camera's position so that the lens or back of the camera is not pointing toward the router.
  8. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  9. Power cycle Wyze Bulb Cam.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  10. Factory reset Wyze Bulb Cam.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up Wyze Bulb Cam like new.
