My Wyze Bulb Cam is not following schedules.
Problem
Your Wyze Bulb Cam is not adhering to the schedules that you set.
Note: Manually turning the light on/off will override the current schedule. The schedule will not execute again until after the light has been turned off. Be sure to turn the light off before testing new schedule settings.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app and tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  5. Confirm that there are no shared users adjusting the lights.
  6. Verify that the Bulb Settings are set correctly.
    1. Navigate to the camera’s settings > Bulb Settings.
    2. Under Activate When, tap Motion.
      1. Tap Lights Off Timer and set it to 15 s while testing, then tap Save.
      2. Tap Schedule and verify it is set to your preferred timeframe.
        1. Set a different schedule to clear any stuck settings, then set it back to your preferred timeframe.
        2. Test the camera during the set timeframe.
    3. Under Ambient Light Settings, tap on Ambient Light.
      1. Toggle it off while testing.
      2. If you want to keep it enabled:
        1. Verify that the Brightness Level is set to a medium brightness.
          • Note: This is different from the brightness level when motion is detected.
        2. Check the Ambient Light Schedule.
          3. Note: Having Ambient Light enabled will keep the camera’s light turned on during the scheduled time.
  7. Power cycle Wyze Bulb Cam.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  8. Factory reset Wyze Bulb Cam.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up Wyze Bulb Cam like new.
