My Wyze Bulb Cam has poor audio quality.
Problem
You hear poor audio quality when speaking through Wyze Bulb Cam or in recorded Events; Wyze Bulb Cam has low/distorted audio.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
  2. If possible, check that Wyze Bulb Cam’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure any protective film is removed from the camera and that there is nothing blocking the camera’s microphone or speaker.
  4. Verify that audio is enabled in the camera’s live stream.
    1. Navigate to the camera’s live stream.
    2. Tap the live stream, then tap the speaker icon to enable sound.
  5. Ensure Record Sound is enabled.
    1. In the Wyze app, go to the camera’s settings > Advanced Settings.
    2. Toggle on Record Sound.
    3. When viewing recordings, ensure the video sound is not muted.
  6. Force close the Wyze app.
  7. Increase the volume on your phone/tablet.
  8. Test the audio on a different phone/tablet, if possible.
  9. If you have a microSD card inserted into the camera, try checking the recordings on a computer to see if the audio in the microSD card recordings has the same issue.
  10. Power cycle Wyze Bulb Cam
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  11. Factory reset Wyze Bulb Cam.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up Wyze Bulb Cam like new.
