Using Wyze App Widgets on Android
What are Wyze app widgets?
Wyze app widgets are a way to manage your Wyze devices from your iOS or Android home screen.
Types of Wyze widgets
  • Device: Check the status of your selected device.
  • Events: View what Events are available in the Wyze app.
  • Shortcuts: Quickly control your Wyze Shortcuts.
  • Wyze Home Monitoring: Your home's monitoring status at a glance.
How do I add a Wyze widget on Android?
1. Tap and hold on the home screen.
2. Tap Widgets.
3. Search for the Wyze.
4. Scroll and tap the widget you want to add.
5. Tap Add.
To remove a Wyze app widget on Android:
Tap and hold on the widget, then drag it to the Remove area.
