Problem
Your Wyze Battery Video Doorbell’s status light is not lighting up, or the device is not powering on.
Troubleshooting
If your Wyze Battery Video Doorbell is battery-powered:
- Verify that the doorbell is being charged using the USB-C to USB-A power cable that it came with.
- Wyze Battery Video Doorbell requires a 5V2A power adapter (not included).
- Ensure the power cable is inserted correctly and securely into the doorbell and adapter.
- Make sure the battery is fully charged.
- It takes about 6 hours to fully charge the battery from 0-100%.
- If the battery is charging, the charging indicator light will be solid red.
- If the battery is fully charged, the charging indicator light will be solid blue.
- If the battery is not charging, refer to My Wyze Battery Video Doorbell won't charge.
- Press and hold the setup button on the back of the doorbell to check if you hear a “ready to connect” voice prompt.
- If so, proceed to set up the doorbell as new.
- Try plugging the doorbell into a different power outlet.
- Try a different power cable or 5V2A power adapter to determine if the cable or adapter is defective.
- Factory reset Wyze Battery Video Doorbell.
- Use the included Doorbell Detaching Pin to remove the doorbell from the back panel, if the doorbell is mounted.
- Remove any microSD card that is inserted into the doorbell.* The next step will reset your device.
- Single-press the SETUP button on the back of the doorbell.
- Pressing the SETUP button will fully reset the doorbell. "Ready to connect" will sound.
- Set up the camera like new by following along in the app. Related article: Wyze Battery Video Doorbell Setup Guide.
If your Wyze Battery Video Doorbell is hardwired:
- If possible, check that the doorbell is receiving power from the breaker to operate properly.
- The doorbell should be receiving 12-24V.
- Power off the doorbell by switching the breaker to the off position.
- Check all wiring to make sure it is secure.
- Ensure that Wyze Battery Video Doorbell was installed properly by following the steps in our Wyze Battery Video Doorbell Installation Guide.
- If you are ever unsure when dealing with wiring, we recommend that you reach out to a licensed electrician at your discretion.
- Power on the doorbell by switching the breaker to the on position.
- Check that the status light is flashing red, and there is a “ready to connect” voice prompt after pressing the setup button on the back of the doorbell.
- The status light is the ring around the doorbell button on the front of the doorbell.
- If so, set up Wyze Battery Video Doorbell as new.
- Uninstall the doorbell and attempt to power the doorbell using the included power cable and a 5V2A power adapter (not included). Refer to the battery-powered section above for troubleshooting steps.
- For users with mechanical chimes, if possible, install the original doorbell and press it to check if the chime box makes a sound.
