Wyze Battery Video Doorbell Setup Troubleshooting
Problem
Your Wyze Battery Video Doorbell is unable to be set up.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Make sure the battery is fully charged.
    • It takes about 6 hours to fully charge the battery from 0-100%.
    • If the battery is charging, the charging indicator light will be solid red.
    • If the battery is fully charged, the charging indicator light will be solid blue.
    • If the battery is not charging, refer to My Wyze Battery Video Doorbell won't charge.
  3. Check that the status light is flashing red, and there is a “ready to connect” voice prompt after pressing the setup button on the back of the doorbell.
  4. Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
    1. Unpair any unused Bluetooth® devices from the phone/tablet.
    2. Toggle Bluetooth® off/on.
  5. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  6. If possible, temporarily disable any VPNs on the mobile device or Wi-Fi router.
  7. Ensure that the phone/tablet is connected to the same Wi-Fi network that is being entered at the Select your network step, that the SSID (Wi-Fi name) is being entered correctly, and that the network is functioning normally.
    • Wyze Battery Video Doorbell is only compatible with 2.4 GHz Wi-Fi networks.
    • The SSID is case-sensitive, and there should be no space before or after the SSID.
    • The SSID should automatically populate if the phone/tablet is connected to Wi-Fi. If it does not auto-populate, it can indicate that the phone/tablet that is being used for setup is not connected to Wi-Fi.
  8. Check that the Wi-Fi password is entered correctly.
    1. Tap on the eye icon to view the password entered.
  9. Make sure the doorbell and phone/tablet are close to the router (within 6-10 feet) during the setup process.
  10. Forget the Wi-Fi network and rejoin the network on the phone/tablet, then try setting up the doorbell again.
  11. Reboot the Wi-Fi router.
  12. If hardwiring, ensure Wyze Battery Video Doorbell was installed properly by following the steps in our Wyze Battery Video Doorbell Installation Guide.
    • If you are ever unsure when dealing with wiring, we recommend that you reach out to a licensed electrician at your discretion.
  13. If hardwired, power cycle Wyze Battery Video Doorbell.
    1. Flip the breaker that is powering the doorbell to the off position, wait 10 full seconds, then flip the breaker back to the on position.
  14. Factory reset Wyze Battery Video Doorbell.
    1. Use the included Doorbell Detaching Pin to remove the doorbell from the back panel, if the doorbell is mounted.
    2. Remove any microSD card that is inserted into the doorbell.* The next step will reset your device.
    3. Single-press the SETUP button on the back of the doorbell.
    4. Pressing the SETUP button will fully reset the doorbell. "Ready to connect" will sound.
    5. Set up the camera like new by following along in the app. Related article: Wyze Battery Video Doorbell Setup Guide.
What happens when you factory reset your Wyze Battery Video Doorbell:
  • The device settings and previous Wi-Fi/setup state are cleared.
  • The current firmware version remains intact.
  • The doorbell must be set up as a new device before it can be used again.
